WLC Config Analyzer - CDH Per WLAN
melcara
Just curious, when using the WLC Config Analyzer, one of the report items says "CDH Per WLAN" either enabled or disabled, what is is this?
Must be a typo:). Disable CHD and see if it changes.
Scott Fella
Sent from my iPhone
-Scott
6 Replies 6
Scott Fella
Do you mean CHD (coverage hole detection)?
-Scott
I was thinking that also, but the tool gave that format
here is the output from the tool
Features per   Controller
Feature Name Controller Name Feature Version Enabled
Load Based Call Admision ControlWLC_NAME4.1FALSE
FIPS 140-2WLC_NAME4.1FALSE
Expedited Bandwith RequestWLC_NAME4.1FALSE
MFP InfraestructureWLC_NAME4.1FALSE
Local EAPWLC_NAME4.1FALSE
DCA Update IntervalWLC_NAME4.1FALSE
TacacsWLC_NAME4.1FALSE
Multiple CountryWLC_NAME4.1FALSE
1250 AP SupportWLC_NAME4.2FALSE
Wired GuestWLC_NAME4.2FALSE
16 SSID per APWLC_NAME4.2FALSE
Syslog messages on APsWLC_NAME4.2FALSE
Backup WLC AP enhancementWLC_NAME4.2FALSE
H-REAP Backup Radius server supportWLC_NAME4.2FALSE
PEAP on Local EAPWLC_NAME4.2FALSE
IPv6 bridged until webauthWLC_NAME4.2FALSE
Enhanced control on MAC for voiceWLC_NAME4.2FALSE
EDCA parametersWLC_NAME4.2TRUE
WMM settings for mixed enviromentsWLC_NAME4.2FALSE
Multicast IGMPWLC_NAME4.2FALSE
Multicast Multicast mode ForwardingWLC_NAME4.2FALSE
Peer to Peer Blocking per WLANWLC_NAME4.2FALSE
AP TelnetWLC_NAME5FALSE
AP SSHWLC_NAME5FALSE
DTIM Per WLANWLC_NAME5FALSE
AP Sniffer mode sent to WiresharkWLC_NAME5FALSE
Increased Mobility Group for roaming up   to 48 controllersWLC_NAME5FALSE
RRM Support for 40 MHzWLC_NAME5.1FALSE
Increased Mobility Group for roaming up   to 72 controllersWLC_NAME5FALSE
2100 Multicast EnhancementsWLC_NAME5.1FALSE
AP dot1x supplicantWLC_NAME5.1FALSE
AP1140 SupportWLC_NAME5.2TRUE
CDH Per WLANWLC_NAME5.2TRUE
AP Locally significant CertificateWLC_NAME5.2FALSE
Mesh SupportWLC_NAME5.2FALSE
Voice over Mesh IndoorWLC_NAME5.2FALSE
More than 16 WLANsWLC_NAME5.2FALSE
Up to 100 local users on H-REAPWLC_NAME5.2FALSE
Do not learn Address for H-REAP clientWLC_NAME5.2FALSE
I just don't know if that is a type'o in the tool or not.
Scott Fella
Sent from my iPhone
-Scott
That was definitly the setting, I guess the wireless team need to update the tool.
They will notice your post. I guess just wait for the next version or you might be able to reply on the wlc config download page.
Scott Fella
Sent from my iPhone
-Scott
Javier Contreras
yes, it is a typo...  I just fixed it, it will be solved on next WLCCA release, hopefully this week.
For any bug reports or feedback (new features, etc), please feel free to write to wlc-conf-app-dev@cisco.com
Regards!
