12-09-2012 07:25 PM - edited 07-03-2021 11:11 PM
Hello Experts
In the bottom screenshot how to detrmine the coverage level, I couldnt find any explicit documentation on that .
Please help
Thanks in advance
Deepak Ahuja
Solved! Go to Solution.
12-10-2012 08:00 AM
I don't understand what you are trying to figure out. What you selected in the image has to do with the coverage hole detection, not ap 'coverage'
Steve
12-10-2012 08:00 AM
Steve
12-10-2012 04:00 PM
Thanks for the reply Steve, what I am trying to understand is the appropiate value to be used for the Coverage level under coverage hole algorithm.
I am not sure how is that value calculated.
Deepak
12-10-2012 11:22 PM
check
http://www.cisco.com/en/US/docs/wireless/controller/7.2/configuration/guide/cg_rrm.html#wp1175067
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008072c759.shtml#chd-ca
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008072c759.shtml#chdca-ex
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008072c759.shtml#app4
