wlc 5508 management interface vlan - access point vlan
Mathieu Sturm
Is it required that the access points are in the same vlan as the management interface on a wlc 5508?
Stephen Rodriguez
No, it's not required.  So long as there is L3 reachability between the AP VLAN(s) and the Management interface that is what matters.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
8 Replies 8
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
Steve is right.... just to add, here is a link to a doc that explains the AP join process in both layer 2 and layer 3.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a00806c9e51.shtml
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
One thing I will add. If you use the management interface and not an ap manger. Make sure under the management interface you check box dynamic ap manager.
Good point George... I keep assuming people don't change that:)
Scott
-Scott
I assume the same for the Gen2 WLC.
HTH,
Steve
HTH,
Steve
There is a story behind this .. Just yesterday my guy was like "aps wont join" .. I let him hammer away at it .. It was the check box
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Your EVIL!!!!
Scott
-Scott
The positive .. He will never forget it again!
