wlc 5508 not seeing all local management users?
kchan
The WLC 5508 is running 7.4.100 code.  This WLC is used as guest anchor controller.  The issue is that from web admin page > local management users, it only shows the first 80 lobbyadmin users.  It allows us to add more lobbyadmin users, but continues to show only the first 80 by alphabetical order.  With this caveat, we cannot see or remove any users that beyond the page limit.
From the SECURITY > General page, it says max 2048 and used 103, so I don't think I have an issue with the user database.
Wonder if anyone has experienced this particular issue?
Thanks in advance.
Stephen Rodriguez
That sounds like a parsing error to me.  I'd be willing to be that the code was never designed to expect 80 Lobby Admin users.
You should be able to use the CLI to show all of them
show mgmtuser
then you can delete them
config mgmtuser delete < username >
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Stephen Rodriguez
show mgmtuser
HTH,
Steve
HTH,
Steve
Thanks Steve.
