WLC 5508 Office extend - remote LAN
latintrpt
I'm confused as to how to setup the remote LAN portion of the office extend solution.  Do I need to set up this remote LAN with a local interface and have it talk to the controller's internal DHCP server?  Or can I set up this remote LAN and anchor it off to my internal controllers?
29 Replies 29
On ANCHOR DMZ WLC...
I have a WLAN called OE-WIRED
It is configured as a REMOTE LAN
Security Policy: None
It is anchored to a 1 foreign controller and not to itself.
EGRESS: Mangement
On FOREIGN WLC...
It is configured as GUEST LAN
It is anchored to itself and nothing else
INGRESS: None
EGRESS: is set to an exisiting WIRED side interface test and working
Profile name is the same and correct.
Ok ...
When you look at the anchors do they show up and up on both side?
Is there a firewall between them?
Did you configure AP groups ?
I as doing this for OE and wired tunneling from AP -> DMZ WLC -> Internal WLC. I wanted the wired phone to terminate via Anchor WLC (DMZ) towards the Internal WLC.
However the anchoring for wireled remote LAN isn´t available like we see on "normal" WLAN SSIDs.
I hoped upgrading to 8.0.110 would solve it but it is still not available.
Not much use to terminate on the DMZ. I saw that someone was complaining about this and had issued a TAC case. Anyone know if this feature will be introduced and when ?
That RLAN reverse tunnel like you mentioned has been removed as a feature from v7.2 or v7.4. You have to have the OEAP join the WLC on the inside. I don't think they have any plans on brining this back.
-Scott
-Scott
Thanks Scott. Do you know why they removed it ?
security concernes or something else ?
I will probably then terminate them on the DMZ anchor and have a special VLAN on the firewall filtering the services needed.
the idea is to use the main wlc where the OEAP is joined to egress the wired traffic.
We have a pretty large deployment. It's best to drop it in the DMZ sonyhe traffic can be inspected ..
I think Viten explained it. Pretty much I noticed it when I upgraded our engineer lab WLC which was in the DMZ.  I liked to be able to keep OEAPs in their own WLC seperste from the inside wlc/APs. Now you have to add the mac filters of each ap to prevent OEAP's that you don't want from joining. That means all you non OEAP's also.
-Scott
-Scott
on the foreign WLC do a:
>show guest-lan X
on the anchor WLC do a:
show remote-lan X
X = the number of your interface ...
Post what you have for both ..
both the DMZ anchor controller and foreign controller show UP and UP between them.
No firewall in between them.
I did configure AP groups, but I have included OE-WIRED in the AP group for my office extend AP's.
The funny part is that when I take the AP 600 home with me, my other wireless SSID's I have broadcasted are working and I can pick up an IP off a foreign controller, so anchoring is working there.  It's just with the wired port it is not working.
DMZ ANCHOR CONTROLLER:
(Cisco Controller) >show remote-lan 2
Remote LAN Identifier............................ 2
Profile Name..................................... OE-WIRED
Status........................................... Enabled
MAC Filtering.................................... Disabled
AAA Policy Override.............................. Disabled
Maximum number of Associated Clients............. 0
Number of Active Clients......................... 0
Exclusionlist.................................... Disabled
Session Timeout.................................. Infinity
Webauth DHCP exclusion........................... Disabled
Interface........................................ management
Remote LAN ACL................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Radius Servers
   Authentication................................ Disabled
   Accounting.................................... Disabled
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
--More-- or (q)uit
   802.11 Authentication:........................ Open System
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
FOREIGN CONTROLLER:
(Cisco Controller) >show guest-lan 2
Guest LAN Identifier............................. 2
Network Admission Control
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
CHD per WLAN..................................... Enabled
Interface........................................ rumcwireless
Multicast Interface.............................. Not Configured
Ingress Interface................................ unconfigured
WLAN ACL......................................... unconfigured
--More-- or (q)uit
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver (best effort)
Radius Servers
Security
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Enabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Mobility Anchor List
GLAN ID     IP Address            Status
2           172.xx.x.xx           Up
BTW -- once this is all worked out. You should consider some type of security on the WIRED side. If someone steals that AP and you have no security on the wired side they can be right into the heart of your network.
For others who may be using this thread in the future. The issue after everything was configured was related to a bug:
You need to make sure you enable a mandatory data rate in 1,2,5.5 or 11 and NOT in the OFDM.
If you find this helpful please rate helpful post ! Thanks
CSCtq76431            Bug Details
Evora:Remote LAN client fails association w/ 802.11b rates not mandatory.
Symptom:
Remote LAN client(s) fail association to wired remote LAN tunneled to WLC.  On
OEAP 602 event log:
*Jun 03 17:01:39.066: (Re)Assoc-Req from 48:5b:39:13:99:bd forwarded to WLC,
wired: yes
*Jun 03 17:01:39.082: received assoc-rsp for idx=3, status=18
From WLC debug client:
*apfMsConnTask_3: Jun 03 13:01:31.832: 48:5b:39:13:99:bd Sending Assoc Response
to station on BSSID ec:c8:82:c0:25:20 (status 18) Ap VapId 2 Slot 0
Conditions:
WLC that supports OEAP 602 running 7.0.116.0 with 802.11g data rate configured
as MANDATORY (6,9,12,18,24,36,48,54).
Workaround:
Do not set 802.11g datarates to Mandatory.
Hi George, Thanks a lot for your instructions. There is very little official Cisco info about RLANs so this has been very useful. However, the problem I have is that I am unable to anchor the Remote LAN on my DMZ controller to the foreign WLC. The mobility anchor option is not available when I click the arrow next to the RLAN (screenshot as attached). Any suggestions?
 Upon further investigation it seems the feature to anchor RLANs has been removed as of version 7.2. (CSCuf52450). We are currently running 7.5.102.0.
I have logged a TAC case to have the feature re-instated in the next release.
