WLC 5508 problem join AP
andres.lorat
Frequent Visitor
Frequent Visitor
I am trying to make a Join of a AP 1131 in a WLC and appears the following error:
*spamApTask0: Sep 08 09:21:41.106: 00:1d:e5:4c:d8:70 Unable to process Discovery
Request from00:1d:e5:4c:d8:70due to missing AP Manager interface
I configure static in the AP the IP of the WLC:
pepe#sh capwap ip config
LWAPP Static IP Configuration
IP Address         186.108.26.155
IP netmask         255.255.255.0
Default Gateway    186.108.26.5
Primary Controller 186.108.26.2
pepe#
Please, let me know your opinion about this.
Thanks.
Andres.
5 Replies 5
Leo Laohoo
Not enough info to process ...
1.  How many AP license is the WLC and how many APs have joined?
2.  Is your time set correctly?
3.  What is the error message or logs on the AP?
Likely that this is a LWAPP coded AP with a statement in the startup config of "cisco-lwapp-controller xxx.xxx.xxx.xxx" where x's equal your old controllers IP address. The 5508 is CAPWAP. Insure that your AP is getting IP from a dhcp server that if needed, has the proper option 43 enabled and pointed to the 5508.
Hi, how are you?.  Thanks a lot for your answer.  I make 'clear lwapp private-config' and configure IP address manually from WLC, and al.l is working fine.
Thanks.
Andrés.
Could you please award points and mark your problem as resolved.
Vinay Sharma
Level 8
Level 8
Hello Andres,
Please mark the Question as Answered, if the provided information is correct and it helped. By doing that others can take benefit as well.
Vinay Sharma
Community Manager – Wireless
Thanks & Regards
