WLC 5508s (SSO v8.5) mgmt interface operations
lcaruso
Level 6
Level 6
Due to organizational readdressing requirements, we need to move all of our APs out of the current WLC management vlan. Unfortunately, I cannot simple edit the interface because of redundancy SSO mode enabled. Is there a way to have more than one management interface defined or any other option?
Thank you.
Now just to add... depending on how comfortable you are with AireOS, what you can do is the following.
Remove one of the controllers and leave the other, this will keep the network up and running. Then you take the controller you removed and connect it to an isolated vlan or switch to allow you to make changes to the management interface, you also want to remove any SSO configurations on that. Then you can place the configured controller on the new subnet. You can then move the aps to that newly configured controller by changing the high availability on the access points. Once the aps have joined, you can remove the other controller and either default it and setup the basic configuration then enable SSO or change the up address and remove SSO. Then connect it to the new management network and the pair the two back into SSO.
You probably want to remove the controller that has the licenses first and set that up again as the primary.
Hope that makes sense.
-Scott
Michael Combs
Hi there,
You are correct, as management or redundancy management interface related details cannot be easily changed on-the-fly once HA-SSO is formed. You will want to scheduled a maintenance window as you will need to disabled HA-SSO, let both WLCs reboot, change the management and redundancy management details, re-enable SSO, then let the WLCs reboot once more as they will then re-form SSO upon powering up.
You can find some additional details here:
https://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-7/High_Availability_DG.html#pgfId-202217
Hope that helps!
-Scott
Sandeep Choudhary
you'll need to break HA and make the necessary changes and enable HA back.
Dont forget to rate helpful posts
