WLC 5520 Ethernet service port (SP) and Management Interface
Bill_Yang1227
Dear Sirs
I install a wlc 5520.
And setup Management Interface(EXP:192.168.1.1) and Ethernet service port (SP) (EXP:192.168.2.1)
I can connect and management Ethernet service port (SP) (EXP:192.168.2.1) with Browser and SSH.
But i can't connect  Management Interface(EXP:192.168.1.1) with Browser and SSH.
I can ping The Management Interface(EXP:192.168.1.1) .
When thinap type "capwap ap primary-base WLC_5520 192.168.1.1",they can Join controller and working normally.
SO,If I use Ethernet service port (SP),I can't connect  Management Interface??
Thanks.
marce1000
 - If you are using that address range, that's OK, but I'd suggest not using the 192.168.1.1 as the management address of the controller as it is often considered a reserved address (for default gatewaying for instance). Take for instance 192.168.2.2)
M.
