10-20-2018 03:18 AM - edited 07-05-2021 09:20 AM
I am not able add the route towards management port
we have two port
1) service port
2) management port
Our communication via management port , but i could not add the route towards that port , the error as below
The error as below
Gateway need to be on service port subnet
IP as below
Mgmt port :- 172.16.8x.x /25
Service port is :- 172.16.8x.x / 24
Solved! Go to Solution.
10-21-2018 02:14 AM
Thank you .
service port not allowed even ip subnet is different. Now i have isolated that . looking for N+1 redundancy in WLC. 5520 .
default going via management port
10-20-2018 08:12 AM
Looks like you did not choose a good network addressing. You are using the same network with different mask.
/25 goes from .1 up to 126 and from .129 up to 254 whilst /24 goes from .1 up to 254.
Try to use two /25 or different network like 172 and 10 or 192.
-If I helped you somehow, please, rate it as useful.-
10-21-2018 12:05 AM
Hi thank you for your response. but the issue not due to of Ip address . Other issues.
even i changed the ip address . but issue remain same .
Note why device considering my management port
10-21-2018 12:28 AM
Service port IP and the management port IP cannot be from from the subnet. Because of your selection of mask, there is a overlap. That's why you get the error message.
10-21-2018 02:14 AM
Thank you .
