Cisco wave-1 outdoor APs are not compatible for Software Defined-Access Wireless solution?
Muhammed Adnan
Level 4
Level 4
Hello Experts,
Have been going through the "Cisco SD-Access Ordering Guide". Herein could not see the listing of 1570 series and IW3700 series APs. Do we need to consider only wave 2 APs for SD-Access Wireless Solution?
Also there's a specific limitation listed out for usage of Wave-1 APs for SD-Access wireless, any technological reason behind the limitations listed against wave 1 APs?
I think it is to do with resource differences between wave 1 & wave 2 APs.
Also a encouragement for customers to buy latest AP models instead of keep using old models.
Rasika
*** Pls rate all useful responses ***
Leo Laohoo
2700/3700 will not be able to support SDA. Cisco wants to accelerate the switch from legacy IOS to the new IOS-XE which newer APs (2800/3800/4800) are made of.
//2700/3700 will not be able to support SDA. Cisco wants to accelerate the switch from legacy IOS to the new IOS-XE which newer APs (2800/3800/4800) are made of.//
Thanks Leo and Rasika.
The latest APs 1800/2800/3800/4800 run IOS-XE or COS? Also I could not get any proper information on who COS is different from IOS. Could someone please shed more light on same?
https://community.cisco.com/t5/wireless-mobility-documents/understanding-access-point-os-images/ta-p/3123952
