WLC 5520 - How to properly use management ports?
MiroslavSestak
I've been trying to organize my network a little better.
Some of the steps was to put WLC into my Equipment Management network.
There is network:
192.168.21.0/24 with Gateway 192.168.21.254. (Forigate)
I put WLC Management interface 192.168.21.210 and adopted all AP-s to the WLC, also reconfigured switches.
Everything working properly, SSID-s are tagging to proper VLAN-s.
One thing that bothers me the most in that setup!
Why the hell all traffic is also loading my Fortigate gateway port 192.168.21.254?
On same switch in same network there is a Mikrotik with DHCP-s for each VLAN being used by Cisco WLS, and he is pushing those VLAN-s directly to internet - works great.
All AP-s are being connect in Local mode.
As far as I've seen traffic goes
Guest > AP > Management VLAN > WLC > WLC's Gateway > then back to Mikrotik > and then out to internet?
Why does it go to WLC's Gateway (Fortigate) 192.168.21.254? It's only management network for WLC.
Guests are - 172.100.0.0/18
Private are - 172.200.0.0/22
There is no 192.168.21.254 network that would generate any traffic.
I'm just testing this solution now:
Service-Port - added to my management network 192.168.21.0/24
I can access web interface of WLC through that without a problem.
Can I use then something virtual for AP-s to call?
Just an update when I run speedtest on some wireless client connected, on Mikrotik I can see duplicated traffic on:
One SFP port on Mikrotik
 VLAN21 - WLC Management Network
 VLAN100 - Guests
 VLAN501 - APManagement for that building.
If my speedtest runs with 80Mbps, all those ports will have 80Mbps (not 160)
and the last
Port SFP2 which is direct access to Internet will have also 80Mbps
 As your Access Points are in local mode, this means that the Access Points talk with WLC on the Management interface and all client traffic goes to the WLC. Considering WLC and Access Points  are in different subnet, the capwap tunnel must pass through your gateway, which is the Fortigate, to get on the WLC. Once the capwap traffic is opened on the WLC and goes back to the Internet, they need to pass through the Fortigate again.
 This is one thing I can suppose.
-If I helped you somehow, please, rate it as useful.-
That's right Flavio!
You explained my situation better then I did :)
How to solve situation like that then?
How usually people do that?
Do you add WLC to you management network, or you just make some /30 just for WLC and that's it?
I really don't know... Never had any chance to check on already configure WLC in produciton
