WLC 5520 no https web GUI
Hi, please give your input to a problem I have just created myself.
I have a Cisco 5520 WLC and it is running just fine. At this moment there are only three APs, but the company wants to extend the wireless network, including guest access. I was testing configurations and created a nice working FlexConnect solution. The only thing that was bothering me was the self-signed certificate on the WebAuth login page.
So I went to the "Security" menu, chose "Certificates, entered all the information for a "CSR WebAuth" certificate, clicked "Generate" and rebooted the controller.
Now I cannot access the web GUI with https any longer. I enabled http web access on the CLI, so I can still reach the web GUI, but I cannot leave this enabled for long. What was my mistake and how do I fix it?
I will answer any question after 9 am CEST tomorrow. Thank you.
I did some regeneration as Flavio had suggested, but that had no effect. But I must have done it wrong. Because in the end that was exactly what I had to do.
So, if you lose access to the https web GUI, enable http web GUI on the CLI with:
config network webmode enable
Then access the web GUI, go to "Management"and then "HTTP-HTTPS". Press "Delete certificate" and then "Regenerate certificate". Go to the "Commands" page, select "Reboot" and press "Save and reboot". Four minutes later you can access the https web GUI again, and even the WebAuth login page works again.
And btw, you can download and execute openssl without installation, but I didn't need it (yet).
Thanks again to Flavio!
Have you tried to regenerate?
  'config certificate generate webauth'
Thank you, the regeneration doesn't solve the problem. I am seeing the solution in the links you provided in your mail, they were very helpful.
I did not create a certificate, only a Certificate Signing Request, so now I don't have a certificate at all, only a pending request. Since I am not allowed to install software, I'll have to wait for the windows admin to come to the office, and he should be able to help me with either installing openssl or importing a company certificate.
Thank you so much. This worked for me 🙂
