WLC 5520 Smart licensing issue with License authorization
Clem58
Level 3
Level 3
I have registering a WLC5520 in the smart licensing portal, generating a token.
The first time I didn't add some licenses for the APs, so I added the required amount.
But after, in the WLC, the status was not refreshed.
So I generated another token and registered again the WLC with "force".
Now I have this status:
Then I registered again the WLC with another token, to see if the APs licences are refreshed, and now I have this status :
Before there were 310 in use here.
How could I solve this issue, is there a way to force the refresh of License Authorization ?
Thanks by advance for your help.
Clem58
Level 3
Level 3
Forget that question, I have succeeded to renew the auth licenses with removing the WLC from smart licensing portal and registering it again from WLC.
For anybody else reading this if are trying to reregister a device that has been registered before then find it on the product instances tab and remove it from there before trying to register again.  You don't need to use a new token every time unless you've limited/expired/deleted that token.
