WLC 7.2 code and Custom WebAuth
David Ritter
Level 10
Level 10
Is there a way to associate a Custom Downloaded page to 1 and only 1 AP/guest account, leaving the rest using the default?
It appears to be a global condition.
the folks at the Law Library have/want their own verbage for their guests and receive the usual daily guest key..  I want the default page for all the other 'guest accounts' on the controller.
currently the LawLib AP resides on a WiSM while all the rest of the production devices are on 5508's, and I want to kill the WiSM.
David
Scott Fella
You best bet is to have a different SSID for that company. Then use ap groups to decide what APs will have which WLAN SSID.
-Scott
Scott Fella
To explain it better, you only can define a certain WebAuth page per SSID and that is why having a separate SSID for the library is a better way of doing things. This allows guest users to know what SSID they should connect to and separates in a way the normal guest from the library guest. It doesn't mean that the guest or library guest won't connect to the other SSID but at least you have the correct verbiage on each custom WebAuth HTML page.
-Scott
Ah, now it is time for a 2nd 'Guest SSID' and I can dedicate that to the LawLibrary and its 1 AP.
Thank you.
No problem. Glad you have it working. Well soon I hope:)
-Scott
