WLC 7.6.100 and PI 2.0
s.hellman
Today we are running software 7.5.102.0 on our 5508 controllers and software 1.3 on PI.
We now considering upgrade to 7.6.100 on the controllers and 2.0 on PI. In the release notes for 7.6.100 it says: "Cisco Prime Infrastructure 1.4.1 is needed to manage Cisco WLC software Release 7.6.100.0", but i guess that they mean 1.4.1 or higher?
2 Accepted Solutions
Sandeep Choudhary
HI,
As per this link 7.4.110.0 is the last support for 5508 WLC.
http://www.cisco.com/en/US/docs/net_mgmt/prime/infrastructure/2.0/release/notes/cpi_rn.html
confirmed through TAC that PI 2.1 is the only release that will support 7.6 WLC code.
It would be good to wait for 2.1 and then upgrade.
More about compatibilty matrix:
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
Rasika Nayanajith
Starting from 7.5 Cisco introduce two parallel train for PI & eventually it will merge ( I hope it is with 2.1). These two are not compatible to each other untill we go to version 2.1
1.3 -> 2.0 -> 2.1
1.4.0 ->1.4.1 -> 2.1
So at the moment you require PI 1.4.1 to manage 7.6.100.0 WLC (like Leo mention, if your controller is already in WCS or any other version of PI, it will remain as active WLC in those platform). But as per the official cisco docuement, the database structure of this 1.4.x platform is completely different to the other one. So Cisco will not support if you have any issues with it.
Rasika
**** Pls rate all useful responses ****
Sandeep Choudhary
HI,
Leo Laohoo
Don't do anything to your PI, if you want.  Upgrade your controller only.
I have 4 pairs of WiSM-2 (and 4 pairs of HA SSO WiSM-2) running 7.6.100.0 but my WCS is currently 7.0.235.0.  I can manage my WiSM-2 from my WCS just fine.
Rasika Nayanajith
1.3 -> 2.0 -> 2.1
Rasika
Thaks for sorting this out. We will wait for next version.
