WLC 8.3.102.0 Code
Steven Williams
Level 10
Level 10
Is anyone running this code version on their controller to support the flexconnect on 1830 APs? I guess there is an SNMP issue with this version and basically its broke and I cannot get it to report to PRIME. Anyone know if this issue is fixed in 8.3.112 version?
Steven Williams
Level 10
Level 10
The issue I have is the WLC doesnt know what interface to send out SNMP on.
I'm not running this version, but it's one of the not really good ones. I suggest you to upgrade in any case to the latest 8.3 version.
Also, do you have one of the more current device packs installed in prime? I suggest to install the latest version, as they sometimes fix such issues in the device packs.
My WLC (although it's 4400, 5508 and 5520) usually send the SNMP data over their management interface, the one on which you access the web gui.
mphoban001
Frequent Visitor
Frequent Visitor
I have the same problem.  Prime will sync with the controller running 8.3.102.0, but no APs show up in Prime's inventory.
Which version, update and patch level of Prime? And which device pack?
