WLC Admin HTTP Sessions & Logging
Florin Barhala
Level 11
Level 11
Is there a way to see existing HTTP users logged on the WLC? I am interested both in a GUI and a CLI method.
Secondly, how can I filter logging in a way similar to ASA class_messages:
logging list LOGIN level errors class vpn
logging list LOGIN message 605004
logging list LOGIN message 605005
Thirdly, is there a way to see a specific part of the WLC configuration; e.g. to see the interface config.
Many thanks!
Sandeep Choudhary
Hi Florin,
I dont think you can check about HTTP session but if anyone have CLI access then you can know by this command:
CLI:
(WLC) >show loginsession
GUI:
Management > User Session
You can filter the logging by severity level:
Check this:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/6-0/configuration/guide/Controller60CG/c60err.html
Dont forget to rate helpful posts
Sandeep Choudhary
Hi Florin,
CLI:
GUI:
Check this:
