WLC and ACS specific authentication criteria query
zohaib.shabir
I have a wireless network with WLC and WCS and ACS integrated for user authentication.Web login has been enabled on the WLC and authentication of Username is done through ACS.
Q1. For specific SSID (TEST) specific username (Tom) is used for authentication,where as Tom cannot be used for authentication for any other
      SSID.
Q2. Weblogin page pushed by WLC is https on virtual IP 1.1.1.1 want it to be pushed through http protocol.
George Stefanick
1) You may want to look at SSID restrcition document id:71811 (google it). In this exmaple you use AD.
2) Yes, turn your WLC to HTTP only. Your guest page will negate the cert. But this is a global setting so your WLC logon will be HTTP as well.
