WLC and AP CLI commands
benolyndav
Level 8
Level 8
 Many ap's that are registered to a WLC and have static IP Adresses, is it possible to reset these to DHCP from the cli of the WLC, 8540. ???
sure what ever suitable for you.
BB
6 Replies 6
config ap static-ip disable Cisco_AP
balaji.bandi
Is the static IP given by DHCP or AP configured manually?
check the below guide to reset
https://www.cisco.com/c/en/us/support/docs/wireless/aironet-1200-series/99763-reset-lwappconfig-lap.html
BB
Its manually configured
Sure- then above document help you to reset and went to DHCP, Make sure AP go onboarding process when it go to DHCP if the Option 43 setup.
BB
No option 43 used,  dns for discovery of primary WLC  is document still ok ??
BB
