WLC and fragmentation threshold
theophile
Hi All, Just curious about the setting named 'fragmentation threshold' under Wireless->802.11b/g/n->Network. Does someoe use it to a specific value? how does it change the client's connection? Thanks for your help
Surendra BG
Hi ,
if you change it, you will send smaller
frames over the air. They will be re-assembled at the end of the link,
so it won't increase ip fragmentations. Specify a low number for areas
where communication is poor or where there is a great deal of radio interference
There is no fixed number as such.. but by default its 2346
Surendra
Surendra BG
Surendra BG
Hi ,
Surendra
Surendra BG
