WEb Authentication
csco10865546
Level 2
Level 2
Hello Folks,
I just bought a 5508 wlc and i have been able to configure it with the 1142 AP.
This works to the stage ofAP to learn IP address from the controller and associating with it,they are also able to give ip address to the clients from the WLAN and internal dhcp scope on the controller
However I configured the Web Auth policy for the Guest SSID and clients connect and get an IP address but it doesnt direct them to web page (internal default) so they are unable to authenticate.I typed in the 1.1.1.1 that i configured for the virtual interface and it doesnt go to the page as well.
Nicolas Darchis
To be redirected, the clients need a working DNS server.
However if you type in any ip address like "http://1.2.3.4", it should be working fine.
If you remove the web authetnication policy on that WLAN, are the clients having correct working access to the network ?
