WLC and LWAP Setup Guide
Hi all,
I want to setup WLC and Light Weight AP with this method:
- APs get the IP address from the DHCP Server.
- WLC IP is not in the same subnet with the APs.
Do I need to configure controller ip on each of the APs?OR It can detect/join the controller automatically?
thanks,
Wan
Rasika Nayanajith
Hi Wan,
You have to configure DHCP option 43. That will enable your AP get WLC information when they getting DHCP IP.
Refer this document for more detail
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/97066-dhcp-option-43-00.html
Rasika
**** Pls rate all useful responses ****
Rasika Nayanajith
Hi Wan,
Rasika
