11-05-2008 09:41 AM - edited 07-03-2021 04:43 PM
I used AirMagnet Planner to place 1242 APs in warehouse using 35mW and -65 dBm cell edges with 20% overlap for 7921G phones.
I plan to use RRM and Dynamic Power Levels. However I noticed when manually setting the power I can choose, 1 thru 5. With 2 50% and 3 being 25%.
Will Dynamic Power Management set AP levels between 25-50%?
11-05-2008 02:07 PM
RRM uses signal strength information from neighbouting APs and assosciated clients to assign a power level, to adjust the behaviour you will need to tweek the RRM sensitivity.
Hope this helps
11-05-2008 02:18 PM
Is the AP Power Level in "dynamic" varying between 25mW and 50mW, say 35mW? Or will it use exactly 6.25, 12.5, 25, 50, 100 for all AP power outputs?
11-06-2008 01:42 PM
The default power setting is âAutomaticâ (uses Radio Resource Management) which I understand is variable but is not documented in the WLC administration guide
