WLC backups showing IP addresses in reverse format
neil_titchener
We're running AIR-WLC2112-K9 with software versions 6.0.196.0 and 5.2.193.0.  When we view the backups all IP addresses within the DHCP and Multicast configuration are in reverse format. If we try a restore using the backed up file it fails because the WLC doesn't accept the IP address format.
Is this a bug and is there a fix for it?
Scott Fella
Those are really old code and do remember seeing that, but IIRC, I don't think I have ever had an issue with restoring code.  I would try to upload the latest 7.0.x code since that is more stable than the code versions you are running.  Just follow the release notes, because you might have to do a multiple upgrade to get to 7.0.x.
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn7_0_240_0.html#wp828197
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Thanks for the reply Scott.  I will be upgrading the WCS and WLCs over the coming weeks.
