WLC CONSOLE PROBLEM
idrisakinyemi
Community Member
tried to login into a 4402 WLC through the console but it is not responding to input through the console.
after asking for the USER, it will not take any input from the keyboard
George Stefanick
For starts go into the WLC and click on MANGAMENT--> SERIAL PORT
should look like this (default)
Serial Port Configuration
Serial Port Login Timeout (minutes)
Baud Rate (bps)
Character Size (bits)8
Flow ControlDisabled
Stop Bits1
ParityNone
Is your settings correct on your end ?
ALSO you are using a null modem cable, right ?
btw ITS 9600 BAUD ...
