Access point power levels
nh6we
I am running a 4400 controller and cant remember how to read the access point power levels.   I know the range is 1 to 8 but what represents full power.  Is it 1 or 8.
6 Replies 6
tysonhall
from command line: show run-config
Tx Power
      Num Of Supported Power Levels ............. 8
      Tx Power Level 1 .......................... 20 dBm
      Tx Power Level 2 .......................... 17 dBm
      Tx Power Level 3 .......................... 14 dBm
      Tx Power Level 4 .......................... 11 dBm
      Tx Power Level 5 .......................... 8 dBm
      Tx Power Level 6 .......................... 5 dBm
      Tx Power Level 7 .......................... 2 dBm
      Tx Power Level 8 .......................... -1 dBm
So, to answer your question: 1
Revised:
5GHz
Tx Power
      Tx Power Level 1 .......................... 17 dBm
      Tx Power Level 2 .......................... 15 dBm
2.4GHz
Tx Power
Hope this helps you out.
Thanks - thats what I needed.
Chris
There is a lttle catch you need to know on the A side ... Depending on the channel you select the TX power is different ..Here you can read more about this ...
http://www.my80211.com/cisco-wlc-labs/2009/10/30/what-you-need-to-know-about-tx-power-and-80211a-5ghz-on-a-ci.html
Example --
If you use channel 36 your max TX power is 11 dBm which is power 1 on the controller.
If you use channel 149 your max TX power is 17 dBm which is power 1 on the controller
I hope this helps...
Please rate helpful post!
Oh yes, nice catch George.  Excellent site, btw, I visit it often.
Hey Hall...
Thanks ... I have some new videos going up in the next 2 weeks and some great troubleshooting tips ...
btw -- Thanks a bunch for the rate!
