WLC design question
mahesh18
Level 7
Level 7
Hi Everyone,
I am configuring customer Wifi Visitor network.
WLC is connected to Switch and Switch is connected to ASA.
WLC,switch and ASA all have management vlan 10.
Switch has its default gateway set to ASA.
wlc---------------vlan 10----------------switch------------------vlan 10-----------------ASA-------internet
Management interface on WLC has its gateway IP  set to IP address of vlan 10  of switch.
IS this design ok?
MAhesh
ali aqrabawi
Level 8
Level 8
technically it should work , if this is L3 switch , and has default route (not default-gateway) toward the ASA .
but why don't you set the WLC gateway as the firewall interface?? rather than having two gateways in same vlan
ali aqrabawi
Level 8
Level 8
Many thanks Ali.
Mahesh
