WLC discovery using DNS
firestartest
Level 3
Level 3
Has anyone successfully got AP's discovering the WLC using the DNS name CISCO-LWAPP-CONTROLLER?
I cant seem to get the dns server to work properly. I added a host called CISCO-LWAPP-CONTROLLER but it keeps appending the domain name to the end of it. I notice that the documentation states the discovery looks for CISCO-LWAPP-CONTROLLER@localdomain
I'm using MS DNS server. Can anyone help or provide a screenshot of the correct setup on dns.
Thanks.
drees
Level 3
Level 3
I've setup the DNS name and let it use my local domain, which it does if you don't specify it. It has worked fine.
Just add the A record of cisco-lwapp-controller with the Management IP Address of the controller. It has to be the management, not the AP manager interface. DNS domain should have no relevance. I haven't seen any reference to DNS domain on a WLC.
I've set this up for several clients and it works every time. Common mistake is using the AP Mgr interface address.
I was curious about the same issue, and ran across this document: www.cos-cug.org/Presentations/Wireless.ppt
It seems to suggest that you put the entry in as:
cisco-lwapp-controller.localdomain
I have an Infoblox DNS appliance, and plan to try this, as well as your suggestion.
Thanks.
It was the .localdomain part causing me problems. When I captured packets I noticed that the AP was querying DNS for CISCO-LWAPP-CONTROLLER and the DNS respone was "not found". NSLOOKUP from a client gave the same response, but clients in the Active Directory domain resolved the address.
I added the DHCP option DOMAIN NAME with the name of my AD domain. The AP then queried for CISCO-LWAPP-CONTROLLER.test.co.uk and this worked.
So I summary I had
DHCP scope for AP's.
DNS servers in options
Defailt Gateway in options
Domain Name in options
