WLC dynamic vlan using openLDAP
reylite
Frequent Visitor
Frequent Visitor
Hi all,
im new here, so this is still planning phase i would like to implement wlc 5520 integration with openLDAP where when user login with 802.1x they get specific vlan base on identity, would it be possible without using ISE ?
need your opinions
thank you
802.1x need ISE,
solve this by using web auth with Mac, and config locally in WLC.
so i need to configure their mac and assign their vlan based on identity ?
its a little inconvenient if they have 1000 user and i need to register their mac address
WLC database is not that big so i will not recommand to use mac address configuration locally on wlc.
Best is to have RADIUS server (ISE or any other).
Dont forget to rate helpful posts
patoberli
I suggest doing that with Radius, for example Freeradius or Windows NPS.
