WLC failover
youssef_1985
hay
I have two WLC 4000 configured as failover.
does the configuration synchronize between the two WLCs?
Scott Fella
No it doesn't sync configuration.... you need to configure each wlc and make sure that both are in the same mobility group in order for the ap's to know of both wlc's.
You would need to configure the access points with a primary, secondary or tertiary wlc, in order for that ap to know which wlc it should be joined with.
-Scott
Scott Fella
-Scott
thanks fella
It is also not a transperant failover since ap's will have to join the secondary or tertiary wlc.
-Scott
