WLC - Geting Problem with Web Portal
marzuki123
When enable the SSID that associate with web portal for guest user, the WLC found difficult to process and the system halt.Unable to get into the management ip for the WLC.
However after disable that particular SSID, the system operates in well condition.
FYI, we are running under version 5.0. Controller model -Wism.
Please advice.
Scott Fella
If I recall, there was a post mentioning that version 5 had issues when webauth is enabled. If I find the bug I will post it, but I know someone on the forum has it. :)
-Scott
Ok. Thanks for the input. Appreciate if somebody out there can post the bug that associate with the issue. Your help mean lot to me. Great thanks.
I'm not sure if this is it or not, but it's in the release notes.
CSCsm98250-After you upgrade the controller to software release 5.0, web authentication stops working, and you can no longer access the controller through HTTP or a Telnet or SSH session
zhenningx
Level 4
Level 4
Maybe this bug: CSCsl94719
Only the login.html can be shown, all other html pages on wism locally cannot be displayed. We see this problem as well.
Zhenning
