WLC Guest Tunnel - client ip address problem
huang.jeff
I can't identify the real ip address from the local wlc if the client associated to the "guest-tunnel ssid", I can only see 0.0.0.0 from the local one. The real ip address appears only on the anchor wlc. Is it correct? And if there is any method that I can identify it from the local one?
Scott Fella
The "real ip" will only show up in the anchor wlc along with other client related info. Since the traffic is tunneled to the anchor, the foreign wlc will not have that info.
Scott Fella
Sent from my iPhone
-Scott
Hi Scott,
Thanks for your reply.
Jeff
