WLC Heartbeat/timeout errors
Kyle Gatlin
Community Member
Had various issues with WLC recently.  Still not sure if it's WLC or LAP that's causing issue.
Here are the logs:
5Thu Mar 29 16:20:10 2012AP Disassociated. Base Radio MAC:c4:71:fe:42:15:ac
6Thu Mar 29 16:20:10 2012AP's Interface:1(unknown type) Operation State Down: Base Radio MAC:c4:71:fe:42:15:ac Cause=Max Retransmission Status:NA
7Thu Mar 29 16:20:10 2012AP's Interface:0(unknown type) Operation State Down: Base Radio MAC:c4:71:fe:42:15:ac Cause=Max Retransmission Status:NA
0 Thu Mar 29 05:16:31 2012 AP Disassociated. Base Radio MAC:c4:71:fe:42:15:ac
1 Thu Mar 29 05:16:31 2012 AP's Interface:1(unknown type) Operation State Down: Base Radio MAC:c4:71:fe:42:15:ac Cause=Heartbeat Timeout
2 Thu Mar 29 05:16:31 2012 AP's Interface:0(unknown type) Operation State Down: Base Radio MAC:c4:71:fe:42:15:ac Cause=Heartbeat Timeout
3 Thu Mar 29 05:09:12 2012 Client Excluded: MACAddress:00:20:00:9a:32:7d Base Radio MAC :00:3a:98:98:fb:b0 Slot: 0 User Name: unknown Ip Address: unknown Reason:802.1x Authentication failed 3 times. ReasonCode: 4
4 Thu Mar 29 05:06:45 2012 Client Excluded: MACAddress:00:20:00:9a:32:7d Base Radio MAC :00:3a:98:98:fb:b0 Slot: 0 User Name: unknown Ip Address: unknown Reason:802.1x Authentication failed 3 times. ReasonCode: 4
5 Thu Mar 29 05:05:09 2012 Client Excluded: MACAddress:00:20:00:9a:32:7d Base Radio MAC :00:3a:98:98:fb:b0 Slot: 0 User Name: unknown Ip Address: unknown Reason:802.1x Authentication failed 3 times. ReasonCode: 4
6 Thu Mar 29 05:02:49 2012 Client Excluded: MACAddress:00:20:00:9a:32:7d Base Radio MAC :00:3a:98:98:fb:b0 Slot: 0 User Name: unknown Ip Address: unknown Reason:802.1x Authentication failed 3 times. ReasonCode: 4
7 Thu Mar 29 05:01:01 2012 Client Excluded: MACAddress:00:20:00:9a:32:7d Base Radio MAC :00:3a:98:98:fb:b0 Slot: 0 User Name: unknown Ip Address: unknown Reason:802.1x Authentication failed 3 times. ReasonCode: 4
8 Thu Mar 29 04:59:24 2012 Client Excluded: MACAddress:00:20:00:9a:32:7d Base Radio MAC :00:3a:98:98:fb:b0 Slot: 0 User Name: unknown Ip Address: unknown Reason:802.1x Authentication failed 3 times. ReasonCode: 4
9 Thu Mar 29 04:56:46 2012 Client Excluded: MACAddress:00:20:00:9a:32:7d Base Radio MAC :00:3a:98:98:fb:b0 Slot: 0 User Name: unknown Ip Address: unknown Reason:802.1x Authentication failed 3 times. ReasonCode: 4
10 Thu Mar 29 04:55:11 2012 Client Excluded: MACAddress:00:20:00:9a:32:7d Base Radio MAC :00:3a:98:98:fb:b0 Slot: 0 User Name: unknown Ip Address: unknown Reason:802.1x Authentication failed 3 times. ReasonCode: 4
11 Thu Mar 29 04:53:59 2012 Coverage hole pre alarm for client[1] 70:de:e2:79:b1:16 on 802.11b/g interface of AP 00:3a:98:98:fb:b0 (AP5475.d09b.baca). Hist: 0 1 7 19 24 4 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
12 Thu Mar 29 04:53:36 2012 Client Excluded: MACAddress:00:20:00:9a:32:7d Base Radio MAC :00:3a:98:98:fb:b0 Slot: 0 User Name: unknown Ip Address: unknown Reason:802.1x Authentication failed 3 times. ReasonCode: 4
13 Thu Mar 29 04:51:26 2012 Client Excluded: MACAddress:00:20:00:9a:32:7d Base Radio MAC :00:3a:98:98:fb:b0 Slot: 0 User Name: unknown Ip Address: unknown Reason:802.1x Authentication failed 3 times. ReasonCode: 4
14 Thu Mar 29 04:48:36 2012 Rogue AP : 00:24:b2:80:a8:aa detected on Base Radio MAC : 00:3a:98:98:f9:c0 Interface no:0(802.11b/g) with RSSI: -58 and SNR: 34 and Classification: unclassified
15 Thu Mar 29 04:48:36 2012 Rogue AP : 00:18:39:d8:91:77 detected on Base Radio MAC : 00:3a:98:98:f9:c0 Interface no:0(802.11b/g) with RSSI: -82 and SNR: 10 and Classification: unclassified
16 Thu Mar 29 04:48:36 2012 Rogue AP : 00:20:a6:a5:18:b5 detected on Base Radio MAC : 00:3a:98:98:f9:c0 Interface no:0(802.11b/g) with RSSI: -82 and SNR: 13 and Classification: unclassified
Log System Time Trap
3 Thu Mar 29 05:31:03 2012 AP Disassociated. Base Radio MAC:c4:71:fe:42:15:ac
4 Thu Mar 29 05:31:03 2012 AP's Interface:1(unknown type) Operation State Down: Base Radio MAC:c4:71:fe:42:15:ac Cause=Heartbeat Timeout
5 Thu Mar 29 05:31:03 2012 AP's Interface:0(unknown type) Operation State Down: Base Radio MAC:c4:71:fe:42:15:ac Cause=Heartbeat Timeout
Issue occurs across two different APs.  One I think may actually be bad?  the one with MAC 15:AC.  No lights come on this device when plugged in.  Keep getting these errors.
The other is working on the LAN at work but not working at remote location.  Gonna head back out there with it and see if it works.
15:AC is a brand new out of the box LAP.
Any ideas of where to start would be appreciated!
11 Replies 11
George Stefanick
Hi Kyle,
Have you looked at the switch port status this ap is connected to, if not lets take a peek and see if there are any issues on the port. Also do a show log on the switch and see if there is any activity on the ap ports as well.
How many WLCs and APs do you have and all the other aps are fine?
The issue has followed the AP across multiple interfaces at location.  AP also generates same error message on WLC at main office as well.
The WLC and two APs are currently working at remote location.  Two APs were sent back.  The non functioning AP and the one that was to replace it but didn't work.  I got one to work at the office here, but the other still generates those errors.  The 15:AC device.
Gonna take the other one out Monday and see if I can get it to work.  But when in remote location, AP would not work on any interface.  Just joins the WLC for a few seconds and then disappears.
What is the connection between the remote locations and the location the WLC is at..?
The AP creates a CAPWAP tunnel between the AP and the WLC. Inside this tunnel there are 2 paths. A control path and a data path. The control path is what keeps your ap connected to the WLC. There are speciifc latecy requirements for this control path to stay up. If you see her up and down. I suspect the latecny could be your issue. What do these WAN links look like ?
Also if they are remote could might consider HREAP local switching perhaps to keep that traffic local.
There's no connection.  They're both networks that I manage that happen to have a similar WLC setup.  Both are independent from each other.
At the remote location it's three 3750s fiber trunked together.  Vlan 130 is the Vlan for wireless.  This vlan is the vlan for the WLC and AP interfaces.
The 3750 that the WLC is connected to is the switch I grabbed some of those logs from.  The AP I was testing with was also hanging off this same switch (15:AC).
The APs that were working were hanging off of the trunked switches.
Sorry I like pictures and crayons sometimes.. Helps me visualize ... So your remote location(s) has a WLC and acces points. There is no WAN invloved. Understood...
Now knowing this a new round of questions ...
What WLC model and code are on
What is your AP model
How is your switch port configured at your WLC
How is your switch port configured at your access points
NP.  Thanks for your help so far!  No WAN.  Remote has a cable modem that hooks up to a Cisco router-on-a-stick with sub interfaces and all that.  I'd also like to note that everythign was working just fine until last week.
Here's the interface pointing to WLC.
interface FastEthernet0/2
description Trunk wlc
switchport trunk allowed vlan 130
switchport mode trunk
end
Here's a switchport for an AP.
interface FastEthernet0/7
switchport access vlan 130
end
I am not at location so I can't get exact WLC info at the moment.  Here's what I got via cdp neigh detail
Device ID: Cisco_d6:a2:e0
Entry address(es):
  IP address: 192.168.130.5
Platform: AIR-WLC2106-K9,  Capabilities: Host
Interface: FastEthernet0/2,  Port ID (outgoing port): Fastethernet0/0/1
Holdtime : 134 sec
Version :
Manufacturer's Name: Cisco Systems Inc.  Product Name: Cisco Controller  Product Version: 6.0.196.0  RTOS Version: 6.0.196.0  Bootloader Version: 4.0.191.0  Build Type: DATA + WPS
advertisement version: 1
Management address(es):
I might recommend upgrading the code on the WLC. The 6 train is very buggy.. I posted this on my blog, that code had some bugs labeled as  "catastrophic", not my words, rather what cisco labeled the bug severity.
http://www.my80211.com/cisco-field-alerts/2010/6/24/bugs-csctf34858-severity-1-catastrophic-wlc-code-levels-6018.html
So this was working fine and then started up all of a sudden ... Any chnages to the network at all ?
Thank you very much!  I'll look up on how to upgrade the WLC to that code base!  Hopefully that does the trick!
Correct.  NO network changes as far as I am aware.
Is the AP currently connected to controller................ No
Time at which the AP joined this controller last time...... Apr 02 12:34:01.451
Type of error that occurred last........................... AP got or has been disconnected
Reason for error that occurred last........................ Timed out while waiting for ECHO repsonse from the AP
Time at which the last join error occurred................. Apr 02 12:38:34.546
(Cisco Controller) show>ap join stats summary c4:71:fe:42:15:ac
Time at which the AP joined this controller last time...... Not applicable
Time at which the last join error occurred................. Apr 02 11:33:12.444
(Cisco Controller) show>ap join stats summary 54:75:d0:9b:bf:f2
Time at which the last join error occurred................. Apr 02 11:58:09.217
