08-15-2019 06:26 PM - edited 07-05-2021 10:51 AM
Hi ,
i have below setup but the ping to management ip is very intermittent
switch A <--> port1 (5520) port2 <--> switch B
the 2 switches are not in vss nor stack. they are on hsrp. currently the wlc LAG is enabled. when the links are connected the ping to management ip is intermittent. when only 1 link is connected the ping is stable. is this normal ? any explanation please. is it possible to achieve link redundancy with this setup? thanks
08-15-2019 06:51 PM
08-16-2019 04:28 AM
You need to disable LAG since they are not in VSS. And remove port-channel in the switch, just regular trunk.
You don't need to delete the 2nd port or shutdown.
Controller>LAG Mode on next reboot>Disabled
Save then reboot.
08-16-2019 07:40 AM
