WLC ISSUE
vaibhav-g
Level 5
Level 5
Hi Team
1. how can we use all the six antennas of a Cisco 1252 Access point? (we are able to use 2.4Ghz radios but not 5GHz )
2. Any configuration required in WLC or access point to have 300 Mbps downlink/uplink to a wireless client?
3. Which wireless adapters (like intel) in laptops will support the 802.11n - 300 Mbps downlink/uplink?
plse let me know the solution.
Vaibhav
andrew.prince
Level 11
Level 11
1. See 2
2. Yes - you need to enable 802.11n radios
3. You need to check with your hardware vendor.
HTH>
Could you elaborate the solution for all those problems.
if possible plse provide document on this.
Vaibhav
