WLC login using ACS 5.1
jmarshman
I was wondering if anyone has successfully managed to configure ACS 5.1 to accept login request from a 5500 WLC?
I've managed to get it configured following the follow link https://supportforums.cisco.com/docs/DOC-14908
but when I try to login to the WLC using my ACS credentials I just get the login screen again.  I've checked the ACS logs and it says my username has passed the authentication process and it matches all the rules I've set.  The only thing I've noticed is my "Privilege Level" is only 1 but I'm not sure if thats correct for a http login.
ok, so it looks like there is a space or a carriage return after the ALL
*tplusTransportThread: Jan 24 11:38:45.980: arg[0] = [28][role1=ALL                   ]
Can you rebuild that attribute and click apply, you might just be able to put the cursor behind teh ALL and hit delete.
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
22 Replies 22
Stephen Rodriguez
when you defined the role is should be ALL  And make sure you do not hit enter behind it.
Steve
HTH,
Steve
I did that already, here is the print screen.
Edit that attribute and see where the cursor will go to.  it should be right behind the ALL.
Steve
HTH,
Steve
I checked and its right next to ALL.
and on the WLC you defined all three servers?
Steve
HTH,
Steve
Yes, and I double checked the shared secret.  Here is a screen shot of the AAA authentication log.
What "command set" should I have configured for this rule?
on the WLC, can you login to the CLI with the local credentials and run
debug aaa tacacs enable
then try to hit the GUI with TACACS credentials
this will show what is coming back from the TACACS server
Steve
HTH,
Steve
As requested,
(Cisco Controller) >config  *tplusTransportThread: Jan 24 11:29:41.519: Forwardi                       ng request to 10.10.11.12 port=49
*tplusTransportThread: Jan 24 11:29:41.520: tplus auth response: type=1 seq_no=2                        session_id=f432fef2 length=16 encrypted=0
*tplusTransportThread: Jan 24 11:29:41.520: TPLUS_AUTHEN_STATUS_GETPASS
*tplusTransportThread: Jan 24 11:29:41.520: auth_cont get_pass reply: pkt_length                       =26
*tplusTransportThread: Jan 24 11:29:41.520: processTplusAuthResponse: Continue a                       uth transaction
*tplusTransportThread: Jan 24 11:29:41.526: tplus auth response: type=1 seq_no=4                        session_id=f432fef2 length=6 encrypted=0
*tplusTransportThread: Jan 24 11:29:41.526: tplus_make_author_request() from tpl                       us_authen_passed returns rc=0
*tplusTransportThread: Jan 24 11:29:41.526: Forwarding request to 10.10.11.12 po                       rt=49
*tplusTransportThread: Jan 24 11:29:41.531: author response body: status=1 arg_c                       nt=1 msg_len=0 data_len=0
*tplusTransportThread: Jan 24 11:29:41.531: arg[0] = [28][role1=ALL
can you post the rest of the config?  and might be best if you did two login attempts.  that way I can see more of the data
Steve
HTH,
Steve
Ok,
I did notice something strange.  If I set the priority order of the login on the WLC to TACACS+ then Local, I can't login using any creditals (local or otherwise) unless I disable the switch port that the ACS is on.
Here is another debug log.
Did you want the running-config?
(Cisco Controller) >*emWeb: Jan 24 11:38:36.782:
                                                 Log to TACACS server(if online): aaa auth mgmt  tacacs local
*aaaQueueReader: Jan 24 11:38:36.783: cmd_buff=[aaa auth mgmt  tacacs local] cmd_buff_len=[27]
*aaaQueueReader: Jan 24 11:38:36.783: tplus_make_acct_request: pkt->length=116 acct_len=116 arg_total_len=83
*tplusTransportThread: Jan 24 11:38:36.835: Forwarding request to 10.10.11.12 port=49
*tplusTransportThread: Jan 24 11:38:36.841: ACCT response length = 5, buffer len = 17
*tplusTransportThread: Jan 24 11:38:36.841: ACCT response body: status=1 msg_len=0 data_len=0
*tplusTransportThread: Jan 24 11:38:36.841: ACCT Socket closed underneath
*tplusTransportThread: Jan 24 11:38:45.967: Forwarding request to 10.10.11.12 port=49
*tplusTransportThread: Jan 24 11:38:45.968: tplus auth response: type=1 seq_no=2 session_id=d443ded8 length=16 encrypted=0
*tplusTransportThread: Jan 24 11:38:45.968: TPLUS_AUTHEN_STATUS_GETPASS
*tplusTransportThread: Jan 24 11:38:45.968: auth_cont get_pass reply: pkt_length=26
*tplusTransportThread: Jan 24 11:38:45.968: processTplusAuthResponse: Continue auth transaction
*tplusTransportThread: Jan 24 11:38:45.974: tplus auth response: type=1 seq_no=4 session_id=d443ded8 length=6 encrypted=0
*tplusTransportThread: Jan 24 11:38:45.974: tplus_make_author_request() from tplus_authen_passed returns rc=0
*tplusTransportThread: Jan 24 11:38:45.974: Forwarding request to 10.10.11.12 port=49
*tplusTransportThread: Jan 24 11:38:45.980: author response body: status=1 arg_cnt=1 msg_len=0 data_len=0
                                            User has the following mgmtRole 0
*tplusTransportThread: Jan 24 11:39:09.451: Forwarding request to 10.10.11.12 port=49
*tplusTransportThread: Jan 24 11:39:09.452: tplus auth response: type=1 seq_no=2 session_id=23510ed4 length=16 encrypted=0
*tplusTransportThread: Jan 24 11:39:09.452: TPLUS_AUTHEN_STATUS_GETPASS
*tplusTransportThread: Jan 24 11:39:09.452: auth_cont get_pass reply: pkt_length=28
*tplusTransportThread: Jan 24 11:39:09.452: processTplusAuthResponse: Continue auth transaction
*tplusTransportThread: Jan 24 11:39:09.457: tplus auth response: type=1 seq_no=4 session_id=23510ed4 length=6 encrypted=0
Steve
HTH,
Steve
Stephen,
That did it!  I can now login with ACS to the WLC... Thanks for the help.
no worries, glad I could help!
Steve
HTH,
Steve
