WLC - Manual AP Failback
serotonin888
I have disabled automatic failback as I would like to failback in a controlled manner should the primary WLC fail. However, is there a "nice" way to do this without either rebooting the AP's or rebooting the secondary WLC?
dancampb
Level 7
Level 7
You could reboot either device like you mentioned or you could just re-enabled AP fallback temporarily.
dancampb
Level 7
Level 7
Thanks - Good point about re-enabling the AP fallback for a short period. Much nicer than rebooting things.
Thanks for your help
