WLC Mobility group across separate subnets
My intention was to create Mobility group between WLC 2504 @ HQ  and 2100 @ remote office.
Configure identical  guest ssid on both WLCs
Tunnel guest ssid traffic to the WLC 2504 which has an interface in DMZ zone.
Note: WLC 2504 lives in subnet 172.17.x.x /16 and WLC 2100 lives in 172.20.x.x/24. Their management interface IP addresses  corresponds to their respective subnet  that is  172.17.x.50/24  and 172.20.x.50/24
The two locations/subnets are  connected via  MPLS network.
Observation
 Mobility group does not form when the controllers are in their respective subnet/location, but when i brought in the remote wlc to HQ and changed it management ip address to HQ subnet, the mobility group was established.
My question, Must all controller have same management subnet for mobility to form ?
How do i handle mobility across different separate subnets  for the purpose of tunnel
Pls post the same output from WLC2 as well.
Since control path & data path is down, your mobility won't work. There should be some config issue or required ports are not open between these two WLCs
Rasika
Rasika Nayanajith
No, you should be able to have mobility peers across L3 boundaries. I would check eping/mping works, which would tell necessary port numbers are open or not across these two points.
http://mrncciew.com/2013/03/24/mobility-ping-tests/
Here is some CLI commands to config and verification
http://mrncciew.com/2013/05/20/mobility-config-via-cli/
Rasika
Hello Rasika,
I checked, but  no reply mping and eping.
(Cisco Controller) >show mobility summary
Mobility Protocol Port........................... 16666
Default Mobility Domain.......................... WLC1
Multicast Mode .................................. Disabled
Mobility Domain ID for 802.11r................... 0xc007
Mobility Keepalive Interval...................... 10
Mobility Keepalive Count......................... 3
Mobility Group Members Configured................ 2
Mobility Control Message DSCP Value.............. 0
Controllers configured in the Mobility Group
 MAC Address        IP Address                                       Group Name                        Multicast IP                                     Status
 1c:de:a7:06:15:40  172.17.0.50                                      WLC1                              0.0.0.0                                          Up
 e0:5f:b9:63:af:20  172.20.0.50                                      WLC2                              0.0.0.0                                          Control and Data Path Down
Rasika
Hi Rasika,
Thanks, i noticed a wrong IP  address for WLC1 under WLC2 mobility settings. Mobility status is now up up on both WLCs.
Second Challenge has to do with internal dhcp on both WLCs
Are my to to use a single internal dhcp on the Anchor controller for all guest irrespective of which controller the client request is coming from ?
Do i have to enable local switching for the guest ssid ? or allow it tunnel
