Cisco WLC 5508 HA AP-SSO not possible
Hi!
A custommer of mine tried to configure HA AP-SSO with two 5508 controllers. After rebooting the primary controller changed into Maintanence Mode.
Version 7.3.101.0
(Cisco Controller) >show redundancy summary
Redundancy Mode = SSO ENABLED
Local State = MAINTENANCE
Peer State = UNKNOWN - Communication Down
Unit = Primary
Unit ID = 25:94:0F:AE:C9:00
Redundancy State = Non Redundant
Mobility MAC = 25:94:0F:AE:C9:00
Maintenance Mode = Enabled
Maintenance cause= Incompatible Software license
Redundancy Management IP Address................. 10.90.249.8
Peer Redundancy Management IP Address............ 10.90.248.8
Redundancy Port IP Address....................... 169.254.249.10
Peer Redundancy Port IP Address.................. 169.254.248.10
License Store: Primary License Storage
StoreIndex: 0 Feature: base Version: 1.0
License Type: Permanent
License State: Active, Not in Use
License Count: Non-Counted
License Priority: Medium
StoreIndex: 1 Feature: base-ap-count Version: 1.0
License State: Active, In Use
License Count: 50 /50 (Active/In-use)
License Store: Evaluation License Storage
StoreIndex: 0 Feature: base-ap-count Version: 1.0
License Type: Evaluation
License State: Inactive
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 4 days
License Count: 500 / 0 (Active/In-use)
License Priority: None
Der sekundäre Controller war aktiv, hatte aber nicht die aktuelle Konfig vom Master übernommen. The secondary controller did not take the masters config.
What did he do wrong? Licence problem?
He told me that both controllers have a 50 AP license.
Thanks in advance for any help. I have no experince so far with 7.3
16 Replies 16
Stephen Rodriguez
Can you share a show interface sumamry from both controllers?
and really dumb question, but he/you do have a cable in the RP port on both controlllers?  Are you going straight back to back, or are you going through a switch?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Scott Fella
v7.3 is your issue.... doesn't work well!  Take a look at this thresd
https://supportforums.cisco.com/message/3838459#3838459
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
I also encountered the same issue
May I know if this is a software issue?
It's a fresh installation and once HA is configured, after reboot, the standby unit showed the same error message
The primary unit has a base AP license while the secondary is a HA SKU unit with no AP license
I read the other thread and planning to upgrade though
Hopefully it will resolve this issue
Hi!
This is what the Cisco TAC suggested, but I am not sure if it helps. My customer will check this on the weekend.
I can see that after configuring HA and rebooting primary the Secondary is on Maintenance Mode.. To resolve this issue please check the below config..
1>> Please enable all the ports on the Secondary WLC
config port adminmode all enable
2>> Reboot the Secondary WLC.
This will resolve the issue and let me know how this works out!!
Just to update,
In my case, upgrading to 7.4.100 solved the issue
Another one of the 7.3.101 HA bugs I suppose
We ran into some issues with the 7.4 in HA and had to downgrade some clients to the 7.3.112.0 code that just came out a week or two agao.
Scott
-Scott
Thanks Mike, this fixed my issue. I am running 7.6.130, what a random fix to this issue. Thanks Cisco! Not only am I certified to configure and troubleshoot your products but I also have random knowledge of your shortcomings.
Andrew Vlasek
I had issues running HA after upgrading from 7.3.110.0. to 7.3.112.0, so maybe it just doesn't work. After the upgrade completed everything appeared to be working fine but when I did a force-switchover none of my 8021x secured SSIDs worked and I had to reboot all APs anyway to make it come back online properly... so much for HA. I unfortunately never tested it fully with the 7.3.110.0 code because I upgraded to it after my new 5508 pair was in production. I upgraded to 7.3.112.0 only because their was a security vulnerability. To me it seems Cisco is not doing enough validation testing of the code and possibly moving a little too fast with their progression in wireless. Can anybody confirm they have tested it even working? I am running all 3602i APs.  I have a TAC case open. Also the upgrade from 7.3.110.0 to 7.3.112.0 took almost two hours because of the firmware upgrade(1.7) that was also recommended!
Interesting....
-Scott
Hi Scott or others listening.
I have come inte problems efter what I presume the "wrong" controller was defined as primary.
After configuration of redundancy IP's on both units I enabled HA SSO on the primary first and not enabling it on the secondary. After the HA SSO was enabled the unit didn't become manageble.
Since I could connect to its Redundancy management IP I could SSH into the unit:
I checked the redundancy status
            Unit = Primary
         Unit ID = 6C:20:56:BD:60:60
    Mobility MAC = 6C:20:56:BD:60:60
Redundancy Management IP Address................. 10.128.112.202
Peer Redundancy Management IP Address............ 10.128.112.203
Redundancy Port IP Address....................... 169.254.112.202
Peer Redundancy Port IP Address.................. 169.254.112.203
(Cisco Controller) >show license summary
StoreIndex:  0Feature: base                              Version: 1.0
StoreIndex:  0Feature: base-ap-count                     Version: 1.0
License State: Active, Not in Use, EULA not accepted
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.3.112.0
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 7.0.112.21
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
Build Type....................................... DATA + WPS
System Name...................................... XXXX
System Location.................................. XXXX
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. SSO
IP Address....................................... 10.128.112.200
Last Reset....................................... Software reset
System Up Time................................... 0 days 0 hrs 13 mins 56 secs
System Timezone Location.........................
Configured Country............................... SE  - Sweden
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +37 C
External Temperature............................. +18 C
Fan Status....................................... OK
State of 802.11b Network......................... Disabled
State of 802.11a Network......................... Disabled
Number of WLANs.................................. 2
Number of Active Clients......................... 0
Burned-in MAC Address............................ 6C:20:56:BD:60:60
Power Supply 1................................... Present, OK
Power Supply 2................................... Absent
Maximum number of APs supported.................. 0
I then did disable redundancy but unfortunately the unit went unreachable
(Cisco Controller) >config redundancy mode none
All unsaved configuration will be saved.
And the system will be reset. Are you sure? (y/n)y
- No connectivity on either management or redundancy management IP
How can I recover this unit, and why did this happen? How can I veryfy the HA-SSO licence?
- Above license info doesn't make sense
Might want to look at this thread.
https://supportforums.cisco.com/message/3910794#3910794
Scott
-Scott
Hi again.
Since I had another site with similar setup where the primary las left in active state, and the secondary in disabled state, I wanted to bring the primary up first on this site too, before enabling HA-SSO on the secondary.
I didn't anticipate any problem doing so as this worked on the other site.
- How can I remotely identify a HA SKU wlc?
Anyway the other thread was rather discouraging, but I assume 7.3.112 should work, Especially since I have this other site up and running w/o problems yet.
I'm not 100% about the state of my primary - will a reboot/powertoggle activate all ports again?
We have several more sites upcoming (two major) - is 7.3.112 in working order or is another code upcoming in 7.3?
I would like to see an updated HA-SSO software matrix.
Thanks in advance
Scott Fella
The compatibility matrix is really what code works with what. Currently still there is no stable version for HA using AP SSO that we have seen. I have seen issues on both the v7.3 versions and the v7.4. I have had clients that just bring up the primary HA and leave the other disconnected. I have had other customers replace the HA with a licensed 5508 to run the normal way with redundancy and I have had customers go to v7.4 and just use the N+1 configuration.
-Scott
Scott Fella
You should take a look at this support link
https://supportforums.cisco.com/docs/DOC-32259
-Scott
