WLC Mobility Group Configuration Interruption?
Sean Devo
Community Member
I have a scenario where I have two WLC-5508 in production that are currently not part of a mobility group. I just wanted to know if there is any downtime if I set up a mobility group between the two controllers? My gut feeling tells me that the current clients connected to the controllers may be kicked off for a short time period while the controllers establish each other as neighbors. Thanks
Best Regards,
Sean
Rasika Nayanajith
No reboot of WLC required for this change. You can go ahead & do this.
Rasika
Thank you!
