Hello i have two WLC (AIR-CT2504-K9) located at two different sites.
there is a total of 51 AP's on one and 16 AP's onthe other and they failover between the two controllers.
The problem is; every 2 weeks the WLC stops working and has to be rebooted.
I have an older controller (2100) and this has the same problem but this was not a crital system and i did not look into it too much.
The two AIR-CT2504-K9 controllers supple wifi for two warehouses and when this fails it causes major problems in production.
A man once told me you should automate a reboot out of hours which not only i cannot seem to do but i find that very odd and not very comforting.
The WLC + ligth AP's recently replaced Autonomus AP's.
Any clue on best practice ?
Should i automate reboots or should i not have to.
any input is appreciated.
WLC code version -
7.4.100.60
kind regards
