Bookmark
Subscribe
6580
WLC power supply issue.
DuJin0509
We have Cisco WLC 5508 and obseved below status from WLC,
Power Supply 2................................... Present, Power Off, Fan On
What does it mean that  power status is off but Fan is on ?  Commonly the power is off and the Fan should be off too, I suspected.
If this status is normal or it means that it is hardware issue of the power supply?
THanks for your prompt reply.
5 Replies 5
Scott Fella
Might be confusing but power supply 2 is off unless PS 1 goes offline. However, the fan is somewhat separate and I have seen the same.  I can check a few we have tomorrow but I believe it's normal.
-Scott
-Scott
M. Wisely
Level 4
Level 4
All of ours are displaying this:
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Is the power supply fully inserted? Is the switch on the power supply on? May be worth removing and re-inserting.
girish_gavandi
I am facing the exact same problem in one of our WLCs. Were you able to find a solution? Do you know what caused it?
I know this is a very old thread, but any information would be useful.
Many Thanks,
Girish
I replaced the power supply module (RMA) and the GUI is showing power supplies as healthy.
Thanks for posting the solution!
