WLC - Radius authorization read/write authority
olgu arabaci
               Hi everbody;
I connect to WLC with radius authorization, i can access read/only mode. How can i fix this. Is this problem because of WLC configuration or Radius Server configuration ??
Sandeep Choudhary
Did your usename is under read only group or read write gourp in Radius server ??
which RADIUS server do u have ??
chekc this:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080782507.shtml
http://mrncciew.com/2013/04/26/wlc-admin-access-via-tacacs/
Also check in wlc :
Management > Local Management USER and see the username and useraccess mode.
Dont forget to arte helpful posts
Scott Fella
It can be both... on the radius, look at the logs and see what shell profile you are being assigned to.  You might need to disconnect the WLC from the network or the radius server briefly so that you can login using a local account that can give you read write so you can make changes.  The WLC will continue to use the radius unless the radius server is not online.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
