WLC Upgrade issue
colin.lynch
Level 3
Level 3
I have installed a pair of 4402 Wireless LAN controllers that were
delivered with 3.2.195.10 software installed. As the rest of our WLCs
are on 4.1.171.0, I wanted to upgrade these 2 as well. I followed the
recommendation from Cisco that they first be upgraded to 4.0 before
installing 4.1. I successfully installed 4.0.206.0 but am now unable
to delete the version 3.2 image to create space for the new 4.1 image. I
can't find any command to delete the old file in either CLI or Web
interface. Any Clues?
Thanks in advance.
ankbhasi
Hi Colin,
You do not need to delete the old file. Once you start upgrading 4.1 release and reboot the controller, controller will boot with 4.1 image as primary image and will keep 4.0.206.0 image as the backup image overriding 3.2 image.
Ankur
*Pls rate all helpfull post
