WLC upgrade up from 5.1.151 https problem
ugisducmanis
Community Member
I  'm trying to upgrade WLC 4402 up from 5.1.151. After upgrade to 5.2 or higher https  interface is inaccessible. If I use any other previous version, all is  OK. Somewhere I found  recomendation to open http before upgrade and use it at first. It  works, but what to do next? To stay on http only?
UgisD.
George Stefanick
Ive upgarded more than my share of WLCs and I cant say I ever had this problem. Is http/https enabled and did you save the config ?
