WLC Voice Audit - Aggressive Load Balancing on WLAN not disabled
r.stockton
I am running v6.0.196 on 2 WLCs.  Aggressive Load Balancing is disabled globally via WCS. (Configure / Controller / General / Aggressive Load Balancing = Disabled).  When running the Voice Audit Tool against the VoWLAN, I receive the following:
"Aggressive Load Balancing on WLAN not Disabled"
I am unable locate the command or the screen to actually disable this on an individual WLAN.  Is this perhaps a code glitch?
-Robert
George Stefanick
GO
WLAN-->ADVANCE--> bottom right hanf side (check box)
You will find client load balancing
George Stefanick
GO
This is not available on the WCS.  I was able to locate this on the individual WLCs.
But thanks for pointing me where to look nonetheless!
-Robert
yea, not all the features (check boxes) on the WLC will be in WCS.
