WLC WIMS 2 - 2 VLANS and 2 SSID's
alex_contreras
Does anyone know how to configure the WLC WISM 2 to have 2 vlans with 2 SSID's.  I'm trying to set this up on a wireless 3702 Access Point.
I'm able to get this configured on an autonomous 3702 Access point using the MBSSID feature
I am able to get 1 wlan / vlan up and running and get with an address of 132.242.*.*
I have a 2nd vlan (99) on our 6509 that I want people to get a 192.168.*.* address.
AC
Leo Laohoo
2 VLANs with 2 SSIDs?
Create two Dynamic Interfaces (make sure the VLANs are on the "allowed vlan" in the 6500).  Create two SSIDs and map each SSID to one of the two Dynamic Interfaces you've created.
Abhishek Abhishek
You just need to create the 2 VLAN and then map it to the SSID. You need to go under WLAN->SSID and map the VLANs created on interface.
sobhardw
Please refer to the below link :
https://supportforums.cisco.com/document/55561/multiple-ssid-multiple-vlans-configuration-example-cisco-aironet-aps
Abhishek Abhishek
Please refer to the links-
http://www.cisco.com/c/en/us/td/docs/wireless/technology/hi_avail/N1_High_Availability_Deployment_Guide/N1_HA_Overview.html
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/69639-wlc-failover.html
- See more at: https://supportforums.cisco.com/discussion/12379206/cisco-wlc-2504-ha-configuration#sthash.B3U4k2vf.dpuf
