Showing results forĀ
Search instead forĀ
Did you mean:Ā
WLC with ACS nd AD?
mastanbabu216
hi all,
i am having  5508 controller and ACS 5.0 server with 3 SSID's Corp_users,guest1 nd guest 2.for the Corp_users required to authenticate from the ACS ,so reuired to integrate  the WLC with ACS server and Active directory.
can any one provide any doc for the same nd guide me waht need to be done in the WLC Side.
venkat
Surendra BG
here is the link to configure ACS and the WLC.. But we do not have a link that has AD as well..
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080665d18.shtml
Lemme know if this answered ur question and please dont forget to rate the usefull posts!!
Surendra
Surendra BG
ACS 5.x has native support for AD. Ad is just another external user database. You simply point the ACS at the IP address of a domain controller and give it credentials to login.
