WLC-WLAN and SSID config
0natanael0
Hi everyone,
Im trying to add a SSID to be broadcasted on an AP. This one didnt exist before as I didnt administer the controller, the issue that I have is that I dont need or want to configure an IP in the interface that one has to create; this because there is a dhcp server in the vlan and I just want it to be layer 2 transparent.
You need to create the interface at the WLC to specify the VLAN ID. Assign an unused IP Address to the WLC. It will not act as a router, just make sure you set "DHCP Proxy mode" to disabled and you´ll get IP addresses from the DHCP Server you have on your LAN.
** Please rate helpful posts **
CCIE #58023
Leo Laohoo
If the dynamic interface doesn't have an IP address then the DHCP request won't know how to get back in.
CCIE #58023
