wlc
Rafael Jimenez
Level 7
Level 7
I found this in a cisco 1300 datasheet.
|AIR-ANT2414S-R* Cisco Aironet 2.4-GHz, 14-dBi sector antenna. |
|* This antenna is not supported by the wireless LAN controllers or by WCS|
What means that this type of antenna is not supported by a WLC controller?
Rob Huffman
Hi Rafael,
This is the reference;
Note that some high-gain antennas are applicable only for the Cisco Aironet 1300 Series operating as a bridge. Because of this, and because the LWAPP-based Cisco Aironet 1300 Series operates only as an access point, these antennas are not supported by Cisco wireless LAN controllers or in the Cisco Wireless Control Software (WCS).
http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps5861/product_data_sheet09186a008022198b.html
Hope this helps!
Rob
